Fuse Block Mounting
Apr 21, 2013
14
So Cal
I bought the Painless Wiring T-Bucket 8 circuit setup and was wondering where everyone usually mounts them. I was thinking maybe on the down tube but don't want it to be seen from the front. Needs to be somewhere that is easy to access. Thanks
Am assuming you bought the waterproof version of the CirKit Boss.
A lot of us use the Centech or Blue Sea (and there are others), mounted under the rider or passenger seat. For myself, I like to have the aux fuse block near the battery and OEM fuse blocks. Don't know if this works with the VW setup for you.
Running wires to the front or back end of the trike has not been a problem with any of my mods so far.
Try to find a spot where it'll stay dry in inclimate weather. If you ride long enough, you will get caught in the rain eventually.
tony29
