When you put the rear tire on mount it in reverse rotation to keep the plies pulled right. You get a lot more rubber on the rear tire.My Electra Glide got about 20,000 miles from a front tire, but the front tire on the TG is ready to be replaced at 10,000. Is there a reason I couldn't run a radial tire as they're sposed to get better milage?
PC
Yes the radial tire will make the front bounce,,,, you should find a rear tire to put on the front of the trike.. Not a trike car tire a motorcycle rear tire Bias Ply. .
Glad I saw this thread. I just bought H-D Anarchy wheels - which are bigger. I told the tech to put the front tire on backwards - then lightening struck me. I forgot that you put a "rear" tire backwards on the front. Now I got to call the dealer and tell them not to reverse the tire - I hope they haven't done it yet. Sometime I'm soooo stupid. :AGGHH:
Just had lightening hit me again. can the front wheel be put on in either rotation??? If so then all they they have to do is put the wheel with the tire on in the correct direction.
Front tire should only go in the direction is meant to turn. The rear tire can be mounted in reverse on the front due the forces it sees and the way the rubber layers are layed and bonded to the rear tire carcass
