I have seen several trikes with 5.5 rake kit.
Others have a 6.0 rake kit.
Are these the same rake, or is there minimul differance?
Exactly my earlier point about overkill...If you put a damper on your front end, you could adjust the tension and make the steering a little stiffer, which I think would benefit you. Many on here suggest tightening the steering head nut....but I believe it puts too much pressure on the bearings to crank on that. If you want info on a damper and how to install it, let me know!I have a 2002 Softail deuce, my friend just put a Frankenstein rear on it. It's really nice, however it has 6 degree rake on it and i find the front brake locks up as the front end is way too light now. Anybody relate?
Making a blanket statement that a 5.5 or 6 degree rake is too much rake doesn't take all the variables into account. What is the year, make and model of the trike its going on? What trike conversion is it going on? In some cases a 6 degree is an excellent choice.
I have a 2002 H-D Softail, Deuce with a frankenstein kit on it. Can somebody please tell me the correct triple tree rake I should be using. I am 60 years old but have good upper body strength. I have M.S. & ride with my walker strapped to the rear. In my younger years I have owned many cycles & had 4 cycle/sidecars, 2BSA's,Matchless,AJS but that was early 70's when you rode what it was! lol I also owned a Sportster trike with three rear wheels (like 2 training wheels) I like riding hard & rely on my front brake a lot.
What do you recommend for a 2004 Wing with a CSC conversion kit?
I understand how the handling & steering effort changes, at speed, when a 4+ or 6+ tree is installed, but what about at low speed. How much harder is it when turning into a parking space at low speed or trying to turn when starting from a dead stop?
Remember, the point is to reduce trail. Cutting it in half from the stock two-wheeler spec is a good all around number in most situations.
