Foot Clutch Conversion
Looking for any information on foot clutch and Jockie shift recommendations busted wrist can't use hand clutch Thanks !!!
Brette......Can't help much on the clutch......But Welcome to Trike Talk...:wave4::wave4:..
If you can use the clutch for shifting while moving, I would recommend a Rekluse clutch. This eliminated the need to clutch when stopping or going slow in traffic. There is a lot of info on this forun about the Rekluse clutch and a good video here
I lost 75% use of my left hand. I went with a Rekluse clutch and like it. The only clutching I do is up shifting. I sort of hook my hand around the end of the clutch handle then pull my whole arm back.
No clutching for down shifts or in traffic.
Rekluse Clutch
I have the Rekluse Clutch and the Pingle Shifter due to crushed left ankle and arthritic left hand, These 2 items are keeping me in the Wind. Both are good additions.
Tri Glide foot Clutches
Had checked out reckluse clutches rather go with foot clutch Found some older threads with info but the sources for parts are old info. Thanks for suggestions will fabricate somthing.
Last summer a guy brought in a 98 Fat Boy 2 wheeler with a home made foot clutch & hand shifter we got it running for him, I got on it put in gear let clutch & it did not work smoothly it would catch then bind up I cranked the throttle did a half wheely it stalled I called the guy told get this the F out of hear before I die, I can usually ride or drive anything. He came down jumped on it put in gear no problem & took off. I think it would be good on a trike. I had seen kits for Tri Glide some were before .
Foot clutch
I have a 2021 Tri glide and also issues with my left hand. Would love to have a foot clutch hand shift but haven’t had any luck. 2 dealers told me they couldn’t help and that would probably void any warranty and a independent shop said because of Abs and brake system probably cause issues? Also heard lots of other negative comments, all I know is that in the 70’s and 80’s that’s all I rode with and loved it. Seems with all the aftermarket things you could buy someone would make a kit . Maybe in the future!
I have converted my 2010 triglide into foot clutch . got bored one day and remembered my 80s shovelhead with a slapstick and suicide clutch.
Seth D
