- Moderator
- #1
I had the opportunity on 6/4/15 to test ride a Hannigan and a Roadsmith at two different businesses. This was my first time on a trike. I plan on test riding a few other manufactures soon.
My first ride observations:
The Hannigan had a 4.5 degree rake kit. The Roadsmith had a 5.5 degree rake kit.
The Roadsmith rear tire pressures were set to 35 lbs. according to the dealer. I thought this seemed high. The dealer stood firm on 35 lbs.
The Hannigan rear tire pressures were set to 25 Lbs.
I thought this seemed low.
Roadsmith manufacture recommends 32 lbs while Hannigan recommends 28 lbs.
The Roadsmith steering inputs were slightly easier but seemed twitchy to subtle steering inputs the faster the speed. The Hannigan, on the other hand, required ever slightly more steering input but did not exhibit the twitchy feeling from subtle steering inputs at any speed. Hard cornering and twisty roads felt steady and tracked well on the Hannigan.
Hannigan has an option to install a 6 degree kit in lieu of the 4.5 degree rake kit.
My questions:
Thanks for any input on these matters.
My questions:
- Will the 6 degree rake kit option make the Hannigan more twitchy in cornering and at speed with proper tire pressures?
- Will setting the Roadsmith rear tire pressures to manufacture recommended pressures reduce the twitchy steering inputs of the 5.5 degree rake kit and the side to side "yawing" sensation?
- Both manufactures demo trikes would veer to the right, no matter what direction the crown in the road was sloping. Constant pressure needed to be applied to the handle bars to keep a straight line. The Roadsmith required considerably more than the Hannigan. Is this related to the rake and/or rear tire pressures? Is this normal for trikes to pull right?
