fault code B1006 on 08 ultra
Jul 22, 2011
15
uk
hi just wondering anyone has had this before ,im getting this code up when i check it on my pv fitted to my bike .
it doesnt have to be run to bring the fault back up after i reset it ,ive checked the battery voltage ,charging rate (max 14.6v)and all the earth connections i can find also removed multi plug under engine going to stator and no corrosion.
but i have found if i switch off after resetting the codes and switch back on before the indicators flash for the alarm it doesnt log any faults.
any ideas?
Update
I've spent all day tracing this fault and I have recently fitted a badlands 3 for LED s I fitted once I remove the badlands the overload fault has cleared!!!!!!
So either faulty unit or incompatible with bike.
LEDS will do different things to different bikes even of the same model. Did you use the equalizer part most of them recommend? That might solve the issue.
Used a badlands 3 ,spoke to supplier I got it from and said I'm not the first one to have a problem with it on a ultra!!!!!
teddycarnes
