Electrical Drain?
I was planning on splitting the trailer pigtail to the Lumina for a light bar to brighten things up. I wasn't too worried as the original lights are LED and the Light bar is too. Not much draw there...But I already have an older set of Halogen driving lights on the lower crash bars and just installed the Mighty Mites...both wired thru the three button accessory switch. So all you smart guys, any problem if they are all running at the same time? Not in the mood to come to a stop light and the bike dies on me. Thanks
And not opposed to changing out the Halogen driving lights to newer LED if that would possibly make a difference. jc
Halogens are a fair load. Not sure what the load for the MM is?
I would fire up the bike and see what the draw is ... I suspect your fine, because if I'm understanding you, all that is powered through the acc port via the three switch harness ... if that is so, the acc port is fused at 15 amps.
Thanks Fuzzy....I was wondering if I am going to tax the total load of the Electrical output of the bike. As I have stated before, I know shit about the Electronics of a motorcycle {at least the newer bikes} Adding another LED Strip wouldn't seem like much more, but sooner or later the amps are gonna exceed the output....right?
One would think .. I ran into that thought with the electrical gear. I have a jacket liner, gloves, pant and socks .... LOL ... Dang I'm getting old. I think my total draw was like 12 amps. I broached this with my Harley service department and they said I would be fine.
Having said all that, I've added the mighty mites since then and used all the electrics while on my trip with the fans. I kept an eye on voltages, didn't even notice a drop in voltage ... what does that mean???? Beats the snot out of me ... but it appears I'm okay.
I think your add of the LED bar is probably fine. Just keep an eye on voltages.
If you have a low amp output Alternator you need to be worried about over heat issues
The stator insulation will heat up and burn out the stator windings = very bad Ju Ju
Most motorcycle systems are simple. Unless it has brushes, then it can have a variable output. Otherwise it always charges at maximum output. Excess is shunted to ground. You should be able to find the wattage specs on your bike then do the math.
They would not have put a Low Amp Alternator on the TriGlide…..would they?
No ;) Have a look at this, it is not current to today's alternators but the principle stays a constant
[h=2]Calculating Excess Electrical Capacity[/h] So exactly how many "gee-whiz" pieces of electronics will your bike power? Well that depends on a few variables. Basically, your bikes excess electrical capacity is the alternators charging output minus the common operating load. Usually these numbers are shown in "watts".
A "watt" is a unit of measure for electrical power (P). In this case, the charging power is the product of the bikes voltage (V) and peak current (I). So P = V * I. What this mean? Simple... if the bikes alternator has a peak rating of 20 amps @ 14 volts then the peak charging output is (20 * 14) or 280 watts.
A motorcycles electrical system consists of three major parts, the alternator, the regulator-rectifier and the battery. The alternator is responsible for producing the power to keep the battery charged and power all of the electrical loads. The regulator-rectifier converts the alternator output from un-useable AC power to useable 14.4 VDC. The battery is used to both start the bike and buffer the power from the alternator.
To calculate your bikes excess electrical capacity, follow these three steps:
STEP #1 – Look up the "charging output" and type of "fuel delivery" from the manufacturer's specification sheet. Typically smaller displacement bikes will have smaller peak charging output.
[h=3]Table 1 – Peak Charging Output[/h]
MakeModelYearFuel DeliveryPeak Charging Output
BuellBlast2001Carbureted297 watts
BMWR1150RT2003Fuel injected700 watts
BMWK1200LT2003Fuel injected840 watts
Ducati9962000Fuel injected520 watts
DucatiST2/ST42002Fuel injected520 watts
HarleyHeritage1998Carbureted360 watts
HarleyElectra Glide2002Fuel injected585 watts
HondaShadow 11002002Carbureted329 watts
HondaST13002003Fuel Injected740 watts
HondaValkyrie2000Carbureted546 watts
HondaGL18002003Fuel Injected1100 watts
KawasakiVulcan 15002000Carbureted377 watts
KawasakiVulcan 15002001Fuel Injected588 watts
KawasakiZX6R2001Carbureted305 watts
SuzukiBandit 12001999Carbureted405 watts
SuzukiV-Strom2002Fuel Injection360 watts
YamahaFJR13002003Fuel Injected490 watts
The bikes alternator output will change at various engine RPM’s. Here is an example of how the engine RPM affects alternator output on a Harley-Davidson Ultra Classic Electra-Glide:
380W @ 1000 RPM578W @ 3000 RPM598W Peak
STEP #2 – Calculate the common operating load. This is the total of all the electrical devices that are part of the bike and will be in operation during normal riding. Do NOT include items like turning indicators and horns since they are only used occasionally. Exceeding the peak charging output for short periods of time is not a problem. The battery will source the extra power needed. However if the power is needed for a long time, the battery will go dead. For this calculation, do NOT include the aftermarket accessories you will be adding; only include the stock items on the bike.
[h=3]Table 2 – Common Operating Loads[/h]
High Beam55 watts
Low Beam55 watts
Number Plate5 watts
Brake/Tail21 watts
Instrument Panel2 watts
Computer25 watts
Fuel Pump60 watts
Cooling Fan60 watts
Electronic Ignition50 watts
A common operating load for a standard fuel injected bike is about 285 watts.
A common operating load for a standard carbureted bike is about 195 watts.
Some bikes leave the low beam on when the high beam is activated. To conserve power, many bikes automatically turn off the low beam when the high beam is turned on. Many larger bikes have additional lighting and miscellaneous loads like radios make sure you include all of the items that operate continuously while riding. Carbureted bikes require about 85 watts less to operate.
STEP #3 - Subtract the operating load from the charging output; this calculation will approximately predict the excess capacity. Usually the larger displacement bikes will have greater excess capacity, but this is not always true as seen in the following six examples (operating loads are approximate):
[h=3]Table 3 – Excess Capacity for 2 small, 2 mid, and 2 big bikes[/h]
ExamplePeakOperatingExcess Capacity
Buell Blast297 watts195 watts102 watts
Kawasaki ZX6R305 watts200 watts105 watts
Ducati ST2/ST4520 watts285 watts245 watts
Suzuki V-Strom360 watts285 watts75 watts
Honda Valkyrie546 watts250 watts296 watts
Vulcan 1500 FI588 watts340 watts248 watts
What do you plan to operate?
This handy table shows how much power many common appliances draw. Only a few appliances draw high power. These are heated clothing, laptops and auxiliary lighting. Small electronics like cell phones and radar detectors draw very little. You can usually run as many of the smaller items as you wish with little or no worry. To find the total power required for all of the accessories you plan to use, add the power rating (watts) for each device. Ranges are provided based on make and model.
[h=3]Table 4 – Common Appliances[/h]
AppliancePower Usage
Heated Garments35 – 77 watts
Aux lights35 – 100 watts (each)
Laptop40 – 60 watts
Cell Phone1 – 3 watts
Radar Detector1 – 3 watts
GPS2 – 6 watts
Portable Music1 – 3 watts
What if I don't have enough power?
Sometimes your favorite bike does not have much excess capacity. For example, the data in STEP #3 shows that V-Strom owners may find that powering several pieces of high power heated clothing kills the battery. There are a few things that can be done to conserve a few precious watts:
  1. Replace standard lights with low power LED lighting (where possible).
  2. Add a circuit that automatically turns the low beam off when the high beam is activated.
  3. A dirty fuel filter can cause the fuel pump to use 120 watts, 60 more than normal. A dirty fuel filter is a common cause for a voltage regulator to fail on a fuel-injected bike.
In Conclusion:
Motorcycle manufacturers have been increasing the alternator output in response to the growing number of electrical appliances available. Most bikes can handle a few 40 watt heated garments without any problems.
According to Widder Canada Inc. “Today’s motorcycles of 500cc or larger can usually handle three (heated) garments together without overtaxing the charging system. Three garments would be equivalent to turning on a 100 watt headlight. Most larger bikes would have no problem riding two-up with both rider and passenger each wearing the full set. Another aspect to consider is that the items will not necessarily be on all the time, or if the thermostat is adjusted to less than full capacity, there will be less draw.”
The Gerbing’s web site states: “…the electrical output of the typical motorcycle continued to increase as motorcycle engineers attempted to satisfy the growing demand for electrical accessories. The result is that all but the smallest bikes can now provide the power needed to generate the needed heat.”
Flyboy7312
