cut the cat out
got the cat cut out and back on this past monday then order some 4" rineharts will be in later this week i think its just me but believe it running cooler and feels like it has a little more power
Definitely will run cooler, More power:Shrug:
I did the stage 1 and ECM recal First, That did give a major power increase red line went to 62 hundred rpms,
Then i did true duals remove the cat also, Cooler yes, But did it add more power over the stage1 not enough to tell, Just more noise.
When you go to true duals there is a low end power loss.
ShonaZiemb
