- Thread starter
- #31
what map are you using and have you done any other tuning since installing map. your numbers sound normal for
a tri glide or a harley in general, 230 - 250 oil temp not out of the question. coolant temps must be normal if your fans are working ( on at 90 C off @ 83C. and no HOT light on gauges. just rolling the throttle on to pass will work if you have lots of room but the engine will do better if you drop down to 5th gear to pass. cooling fans dont do much at 70 MPH. My wife got blisters on her right leg from her TG , In the process of doing mods to help it out,
BUT it is still a big air cooled engine (only the exhaust port is liquid cooled) for the most part and will put out lots of heat when worked hard and yes to me 1500 to 1800 hundred LBS climbing hills is working the motor.
Appreciate the reply Tom.
Bummer to to hear about the extreme heat you wife is experiencing. Hope you find a solution soon. I feel heat but nothing like blistering heat.
The PV is my first experience with a tuner and I have no idea what I'm doing with it. Just downloaded a user guide for it yesterday and will start digging into it. The tune I began with is the one supplied with it according to my setup. I took that tune and ran 3 or 4 auto tunes around town with the supplied tune and whatever the results of the auto tune is what I'm running. It's time I learn more on the capabilities of the PV and how it will work best for me and my setup.
Been some discussion above about checking the trike to see if any codes have been thrown. None displayed on the PV. Would the ECM on the trike store codes that the PV would not detect? Want to make sure I'm not missing something.
To me it appears that the radiators and fans are working properly. I took the front covers off to check for air flow blockage, (fin damage, excessive bugs and debri) all looked good. Fans definitely running and expelling heat from the sides of the lowers. Coolant temps go up when under load and down as expected when not under load. They appear to stay steady on the flats. Pretty much what I would expect from a liquid cooled motor.
Engine oil temp does appear to be running in a decent temp range, (highly unscientific using the thermometers I described above and had available at the time). Would like to find a better way to check oil temp with more accurate results. Any suggestions welcome?
Appreciate the responses. Keep them coming if you have more. Learning more about this trike daily. Hope to get it cooled down as much as possible. Truly enjoy the time that Laura and I spend on it.
