Clutch Issue 2010
Oct 29, 2016
7
2
Victoria Australia
Hi everyone long time reader 1st time poster, got stuck today in major traffic jam heading up into mountains today & while bike wasn't overheating (LoveJugs & Ceramic Exhaust) the clutch got a decent workout. Cut a long story short found once off the mountain the clutch now starts to slip once i apply the power. My question is this clutch now stuffed & requires replacement, If so is there a heavy duty clutch available thanks
Welcome to Trike-Talk...From New Jersey....:wave4:
And yes their are heavy duty clutch's available , And i'm sure someone with more knowledge will chime in soon with the info you need...
And again... Welcome...:clapping:
:Agree: see if you can adjust the clutch first. How many miles on the 2010?
You may have to replace the discs? But try an adjustment first.
I believe you have a cable clutch too. That has to be done at the same time as the clutch adjustment unless you feel its ok.
Trike has 56000klm (35000 miles) believe its original clutch will try adjusting but little concerned as we are going to be pulling a small trailer in near future.
is there a heavy duty clutch available asking here as Trikes aren't sold in Australia in great numbers with Dealers having little knowledge on their set up.
Baker Clutch's..... Google it....J and R Cycle sells them....
Hope this helps......
First shot is to adjust and see how it goes...but sounds like you may have glazed the disks.
If that is the case (an adjustment does not fix it), then all you need is to replace the disks and get a strong clutch spring....I am pretty sure the cost for the stronger spring is in the $35 area.
In fact, if the adjustment does not fix it, I would try just a stronger spring first, as long as there is still good material on the disks.
I would definitely change out the primary fluid right away.
Just looked up the link for the heavier spring-
https://www.harley-davidson.com/store/heavy-duty-stock-clutch-spring
btw, ceramic pipes and Love Jugs are not enough to cool down a 2010 Tri-Glide to get it into the optimum operating temps.
Here's a useful LINK on heat and HD engines.
Clutch
Get the info you need from Mr. Wizzard. He knows his stuff. I followed his advise with a 1+ clutch, Hayden chain tensioner and a Clutch Wiz. After a few years, my 2012 is doing just fine.
Kickstand_Korner
