Clock Setting
Dec 15, 2010
111
19
Las Vegas, NV
Terry
Can someone tell me how to set the clock on my Stallion, or direct me to a site with the info?<br /><br />
Also the heater does not put out any heat. The A/C works fine along with the blower, any idea what to look for?<br /><br />
Have e-mailed TMS but no answer from them.<br /><br />
Thanks for any help. This site has helped me sooo many times.<br /><br />
Terry
If everything else "fails" call Cust Serv @ 1-800-908-7453 or (903) 842-3094. Don't forget to set it ahead 1 hour next Sunday. ( <img src="images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" /> )
When i have trouble setting a clock, or any electrical gizmo, I just ask any teenager. Takes them 2 minutes, And without the help of a manual. :Shrug:
I'm curious, who did you email at TMS and when? It's rare they don't respond or reply to emails with issues and concerns. Maybe it fell through the cracks, or maybe the wrong email recipient?
All settings need to be done at the radio in the trunk and then press the display on the radio to either see the time or channel on the dash remote...on the heater issue cbeck to make sure you have plenty of coolant (Ford premium Gold type) in the resevoir becaue there can be an air void in line...That what happened on mine..
Again, thanks to all. The clock is now set, Still no luck with the heater so guess when i go to the Ford place ill have them check it out. <br /><br />
Only 50 plus days before the ride down to Cabo San Lucas so want everything working right. Love this web site.<br /><br />
Terry
Terry, <br />
<br />
The heater not working sounds like the heater control module. It is located on the HVAC unit. If you remove the right rear wheel, look at the HVAC and right on top of the duct there is a black box with a wiring harness coming from it. there are two plugs on the harness, and three screws holding the module in place. Easy fix, and only takes about an hour to and hour and a half.<br />
<br />
Hope that helps.
Trike#1
