Checking SWR on 2017
Apr 29, 2011
55
29
Longmont, CO
Dudley
I had a 2009 GL1800 and a radio shack SWR meter. The 2009 GL1800 connectors were standard motorola. I tried to use them on my new 2017 but the CB connectors are just a little smaller in diameter. Does anyone know what these connectors are?
I've not had a customer with a newer Wing requesting an antenna tune, and thus don't have the adapters either. I too have the Motorola ones that I ordered long ago from Radio Shack. I see now they no longer sell them on their web page. I checked Sierra Electronics page and don't see the newer ones their either.
http://www.sierra-mc.com/proddetail.asp?prod=SIE-SWR12
Unfortunately, your best bet might be a good truck stop. If you find the correct adapter numbers, please post them so that I can get them too.
Or like this..Mini 259 conn
Something here is not making sense. Honda uses the same part number for all antennas from 2001-17. To me that means the antenna pigtail for all those years is the same and has not changed.
I surprised to hear the connectors are not the same also!!!! Thought they were all the same, which is why my previous post suggested Sierra Electronics as a source.
Might give them a call @ Toll Free: 1-800-338-6938
when I called Sierra told them I had installed a Hondaline CB in a 2012 and needed to check the SW those are the adapters he sold me. I also needed a meter and they were as reasonable as anywhere so I also got a SWR meter.
Im about a 2 hr. ride from Sierra Electronics. I have stopped by their place of business several times an regardless of who I talk with or what ever I've bought I can only speak of them positively.
CB connector Mystery solved
On my 2009 the CB antenna connectors were under the seat. On my 2017, the ones I was looking at are for the AM/FM antenna. The CB unit is mounted in the trunk and on the left side are the motorola connectors. (It was dealer installed so I didn't know where it was)
AAAAH. mystery solved, thanks for the response! So many never explain what the answer is when they post a problem,
Marks2024
