Catless Header
Does anyone know if the exhaust from a 2009 streetglide had the cat? Will they fit a 2012 triglide? If so, I wonder if that would reduce the heat that I currently experience. Suggestions and advice would be great.
All 2009 touring head pipes except California, CVO and Export are without a cat. To install a 2 wheel touring head pipe on a Triglide you will need an adapter for the right side which lengthens and has the proper bend, I know Vance & Hines makes one. You could also get the 2009 head pipe and have Fullsac turn it into a sport pipe which would have the correct back section and not have a cat once he is done. Doing just the head pipe will reduce some heat but not totally, to get rid of more you need to tune it.
Ron A
