I have mine on the axle too.
A strut rod to triangle brace and a bolt and tab 90 degrees away stopped mine from vibrating and cracking. The bracket to the axle flange is 3/16 thick also.
Yep, you would have to support the top part of the fender as shown by Deathbysnusnu! Otherwise they will vibrate and break. As he said, his mounting brackets are 3/16" thick which I would imagine they would have to be that or 1/4" as well as supporting the top portion.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
