BrightAssTailights
Jul 29, 2010
67
North Carolina
I just put these on my TG, if you have not seen them go to the web site or to a HD dealer they are killer. I can't believe how bright these things are and I got the dim 4 LED ones they make a 12 LED unit, probably just explodes the car behind you. If you are looking for something to make the rear more noticeable, check them out. Jerry
<div class="bbcode_quote">
<div class="quote_container">
<div class="bbcode_postedby">
<img src="images/misc/quote_icon.png" alt="Quote" /> Originally Posted by <strong>Helipilot</strong>
<a href="showthread.php?p=50591#post50591" rel="nofollow"><img class="inlineimg" src="images/buttons/viewpost-right.png" alt="View Post" /></a>
</div>
<div class="message">I just put these on my TG, if you have not seen them go to the web site or to a HD dealer they are killer. I can't believe how bright these things are and I got the dim 4 LED ones they make a 12 LED unit, probably just explodes the car behind you. If you are looking for something to make the rear more noticeable, check them out. Jerry</div>
</div>
</div>
</div>Do you have any pictures or a web site to reference these lights??<br />
<br />
<a href="showthread.php?p=50676#post50676" rel="nofollow"><img class="inlineimg" src="images/buttons/viewpost-right.png" alt="View Post" /></a>
</div>
<div class="message">Yes here is the web page <a href="http://www.brightasslights.com/site/" target="_blank">Home | BAL</a>.</div>
</div>
</div>
</div>Thanks!!<br />
<br />
Do you have any pictures with them on your Tri Glide you could post?? Do the brake lights and turn signals work just as the stock lights??
Everything works perfect just plug one plug in and two screws hold the light on. I have had more remarks on the tail lights than the trike. They have videos on the website and on youtube. Its raining here through Friday maybe Saturday I can get a video up. Jerry
<a href="showthread.php?p=50868#post50868" rel="nofollow"><img class="inlineimg" src="images/buttons/viewpost-right.png" alt="View Post" /></a>
</div>
<div class="message">Everything works perfect just plug one plug in and two screws hold the light on. I have had more remarks on the tail lights than the trike. They have videos on the website and on youtube. Its raining here through Friday maybe Saturday I can get a video up. Jerry</div>
</div>
</div>
</div>Yea I seen them on there web site but wanted to see how they looked on the trike and make sure all functions worked once installed.<br />
<br />
Thanks Again
<img src="images/misc/quote_icon.png" alt="Quote" /> Originally Posted by <strong>trikermutha</strong>
<a href="showthread.php?p=50869#post50869" rel="nofollow"><img class="inlineimg" src="images/buttons/viewpost-right.png" alt="View Post" /></a>
</div>
<div class="message">Yea I seen them on there web site but wanted to see how they looked on the trike and make sure all functions worked once installed.<br />
<br />
Thanks Again</div>
</div>
</div>
</div>They look stock when not lite. But they sure light up when you put them on. I have the bright 12 led ones and they do the job. Highly recommended.
<img src="images/misc/quote_icon.png" alt="Quote" /> Originally Posted by <strong>tmigala</strong>
<a href="showthread.php?p=50905#post50905" rel="nofollow"><img class="inlineimg" src="images/buttons/viewpost-right.png" alt="View Post" /></a>
</div>
<div class="message">They look stock when not lite. But they sure light up when you put them on. I have the bright 12 led ones and they do the job. Highly recommended.</div>
</div>
</div>
</div>Wow I like to see the 12 led and the 4 led on the Tri Glide to compare which I like better.<br />
The only down fall is the price tiag of these units.<br />
<br />
Thanks for all your info on this topic.
<a href="showthread.php?p=50921#post50921" rel="nofollow"><img class="inlineimg" src="images/buttons/viewpost-right.png" alt="View Post" /></a>
</div>
<div class="message">Wow I like to see the 12 led and the 4 led on the Tri Glide to compare which I like better.<br />
<br />
Thanks for all your info on this topic.</div>
</div>
</div>
</div>Worth every penny. You WILL BE SEEN from the back.
Does anyone know of a dealer that sells the lights at a discounted price??
The manufacturer will not sell them any cheaper.
Does anyone have any pictures/videos of the lights on there Tri Glide they could post?
Update... I purchased the Bright ass lights and installed one of them on the Tri Glide(2010)
I tested the running light and works fine ,but once I turned on my turn signals its starts with a normal flashing then goes into super warp mode.(super fast flashing)
I contacted Brightasslights.com and it appears it works fine on some of the Tri Glide trikes they tested but others they do not. Sounds weird to me because they are all setup the same from harley.
So my next plan is to install a load equalizer and see what happens.
By the way the lights are bright .I put it on its highest brightness setting. You hit the brakes and boy it lights up the garage.
If this does not work everything is going back for a refund.
I have a 2011 tri and they work perfect on mine. I just plugged them in so I have no idea what the difference would be. They are some bright ass tailightss though! I would love to see some of the 12 LED ones though they have to be BAD. Good luck on finding the cause. Jerry
Tech support was baffeled why they worked on some of Tri Glide's and the others did the same as mine ..
I have the 12 light version on my trike and the first time I turned them on in a closed garage they burned a hole in my steel door! They work fine on my trike set to the brightest running and 4 on the brake pattern(Stock)
They say the 12 led version is more for the municipil vehicles. The 6 Led version are bright enough . Man you must light up the neighborhood with the 12 LED version.
Update
The load equalizer took care of the quick flashing issue when installing the new BRight ass Lights.
It too dam cold to stay in the garage to test further..LOL
Great, I think if more people check into these they will like what they see you sure as hell can't miss them. They are a good safety feature and look cool also. Glad to hear you found a fix. Jerry
Delverc
