brake problem 2013 stallion
Nov 23, 2010
42
4
aiken, sc
Lost my brakes this afternoon....pedal went to the floor....was able to pump a little and stop...left a trail of fluid and a good size puddle in the garage...I can't get under it to see exactly where it is....has anybody else had a similar problem and is it an easy fix or should I be heading to the dealer...who is closed on Mondays...of course
Thanks for any info or help
I had a bleeder work loose on one of the front calibers. bleed the brakes and was back in business. Need to know where the fluid is coming from to give you a good answer.
Could be a brake line that came loose or got pinched. Also the reservoir is attached to the booster. You are going to have to get it lifted and look under it. The brake system is standard and should be able to have any garage look at it and repair. Good luck
Possibily the distribution valve which is attached to the booster. I think some were replaced due to leaking. Mine does not actually leak, but it accumulates dirt on it over time, so there is enough there to attract dirt. Just a thought.
Thanks guys,......brought it up to Cherokee Trikes today and was informed that the 2013,s have had a problem with the distribution valve and they will replace it.....thanks again for the replies
Cline
