Brake Pedal Extension
rmrc51
Lost In The 50's
Feb 2, 2009
4,172
149
Palmyra, VA
Rich
Do any of you know of an extension that I can put on the brake pedal of my Valkyrie that would extend the surface out away from the body of the bike?
The reason I ask is that my feet, when sitting, stick out at least a 45 degree angle and its a PIA to try and straighten my foot to catch the brake pedal. I barely touch the extreme right of the foot brake now and that's with the Kurykan cover addition on it.
Thanks in advance for any suggestions or solutions.
Rich-
Show Chrome makes a wide slip-on pedal cover that should do the trick for you. Its wider and taller and works well. See part number: 1-328 - Brake Pedal Cover. It can be ordered here:Scoot Works (see last item at bottom of page)
You might check out wingstuff.com . They have a brake pedal extension that measures 4 1/2" w x 1 15/16" d made from billet aluminum and is chrome plated. It is for GL1800 and bikes with a large pedal.
Thanks guys. I was mistaken when I said I had a Kuryakan cover. It's the Show Chrome one the Bazooka posted.
I will check the one Wingking51 mentioned on Wingstuff.com.
Thanks again. :)
Boatpaddle
