Just wondering if someone in The Trike World has a set of detailed stepped instructions on bleeding the disc brake system on a GL1800 / Lehman Monarch II build.
Previous post should give you the information you seek once you select the kit you actually have. Notice there are different Monarch II kits depending on year. I seem to recall someone saying the later ones have delinked brake system, although I don't see any difference in the manuals, so the bleeding procedure may be different. The correct install manual for your conversion will tell you how to do it.... :xszpv::xszpv:
Goldrush,
My kit does have linked brakes. Front lever only operates the front brake calipers. The rear brake pedal operates both front and rear brakes.
I do have the standard shop service manual for the GL but was looking for specific instructions
for the Trike kit. Not sure how the sequence would be when you have 2 calipers in the rear that work off the brake pedal.
Go to the link DAWG provided and download the correct install manual for your kit. Go to the brake bleed instructions in that manual and have fun. I have found that mechanical bleeders do not work well but that may be the operator (not really). I have a good friend that has helped me bleed several systems the old fashion way. When we get done the brakes are solid as a rock! Sometimes old fashion is good.... :xszpv::xszpv:
