Boom Box GTS
molokaimike
150+ Posts
Gold Member
Mar 28, 2020
182
250
Surprise, AZ
Mike
On my 2020 when I activate the information screen and select the engine mode it says "Engine oil OK". Is there a way to make it display the oil pressure or oil temp.
Nope. Harley has never offered an oil temp display and they took away the oil pressure reading on the 2019 model year I think it was.
My 17 Triglide and now my 19 Triglide do not have a pressure gauge my 11 Triglide had a pressure gauge which would fog up in the morning so that gauge and a token would get me a ride on the subway😄 A pressure gauge is Just something else to look at and get you nervous... And probably wouldn’t get your attention till it’s too late unless it has a corresponding red idiot light😱
not to hijack this thread, but I have a 2020 and two questions on the GTS
1. under set up, just under the language tab is one for PROJECTION on/off cant figure out what it does.
2. under the info screen it shows length and time of ride, but I have not been able to figure how to turn this on. Is it only for routes you are tracking? is it not Active each time you ride?
thanks. again sorry to hijack this thread
Projection is for Apple CarPlay. In order to use CarPlay projection must be ON.
I do think the length and time of ride is only for routes you have created / loaded and activated in the gps. I've not been able to verify this but I think this information is correct.
on the projection part thanks,
on the other, what I am talking about.. It's the trip summary. have not figured out how to use it.
I have a 2015 and the trip summary is accessed thru the GPS function and will reset when you turn the bike off. I would expect that the same would be true on the newer models also.
It can be used continuous, by selecting some destination and hit the GO. If you do not stop the route then will give you the MPG, and other information. The only problem is the Navigation witch will keep telling you to turn around, I'm not a big music listener so mute the system. Just one way to work around the system.
Does anybody else's radio reception on stink, on their 2019? Mine sure does. and yes check connections.
My 11'17' And now my 19 does....But i never use the radio away, I use an iPod and or a thumb drive ...
wzejda
