BMW trike clunk on back differential
Sep 19, 2021
2
England
My bmw k1200 lt has a panther trike conversion which has a freelander back differential,.when I let the clutch out there is a clunk from the back differential,I have put a reconditioned differential and new cv joint ,but clunk is still the same .any suggestions what it could be.some one said it could be coming from the front gear box ,or do I jest get on and enjoy the trike
Brian.......Welcome to Trike-Talk......:wave4::wave4:...Sorry i don't know BMW's...But if it were a Harley is sounds like a Compensator...?...
Hopefully someone will chime in with better info...;Again' Welcome to Trike-Talk :wave4:...
Hi Brian, :welcome: to Trike Talk and your first post
Can you post up some pictures of the rear end?
Please stop by the New Members section and tell us about you and your trike;)
Good morning Brian . Is it possible the dif is torquing up and hitting somthing :Shrug: just a thought.
Good point, first thing to check, I would also check the pinion lash
Does this also have a driveshaft with u joints? If it does another place to check, a bad joint can cause this noise and if bad enough it could leave you stranded
BMW
Thank you yes it has a drive shaft but I check for any play when I changed the differential.the reconditioned differential had a knock in it when I moved the drive pinion back and forth,when I took the old differential out they were both the same knocking when moving the drive pinion left and right,don’t know if this is normal or both are faulty
Gyl
