Best accessory you put on your trike and why
Feb 17, 2019
246
216
Lyons, NE
David
Thinking of putting a little money in to the trike. Thinking may be fork brace. Just wondering whatelse i should think about.
Air horns. They really get the "air-heads" attention. The good ones are much louder than stock horns. I'm running a Stobel that's plenty loud for me, but there may be better ones I don't know about. Any good horn will likely require a relay.
PC
My bike was used when I bought it and has a good amount of extra lighting. That would have been my first addition in order to be seen. The biggest bang for my buck so far has been a fork brace. The bike handled pretty good before but after installing a brace it is much better and I do believe the steering is a bit easier...... Jim
I had a 12 volt plug installed in the storage compartment on the left side. I mounted a RAM GPS holder that bolts onto my clutch reservoir for my standard $99 GPS. Not only does it help when I need directions it shows me when there is a sharp curve coming and which direction so I can navigate which side of the road I want to be on. It also comes in handy when I go on my "ride to nowhere" so I can actually get home the same day! LOL
Ne farmer, Using a piece of 3/4" angle iron I mounted the air horn right where the stock horn was. Painted everything flat black so it blends in with the engine.
PC
2+2 wide sweepers made all the difference in the world on riding my Trike. Second will probably be the MT mechanical reverse I just ordered.
X_RfjCf6hQofYyjaQYX9tXZ3VEI3FrynT_GuQ7w1CgzXmChYAqBqlSG42H9MvYdRlTqw3abSjKvuUemKh3cXzK_n_7Lis2mfBw
:D
Like Jack I think the Mini Might Fans. Close second is the 2+2 Wide sweepers if I didn't swap them I would have sold the Trike.
Not trying to highjack the thread but I looked the 2t2 wide sweepers up on JP Cycles and it said they would not fit my 2017 Tri? And the best accessary I have put on my trike is my butt in the seat:laugh:.
Looks like they will fit but are just out of stock right now at J&P.
Call Khrome Werks and talk to them really nice people they let me know it would fit my 09. J&P said the same thing then. Fred
I have installed air horns great safety investment
PC
Good message neighbor, I have a 1800 Goldwing Champion Trike. I also took extra safety measures and installed me a set of air horns on my trike. I found a set on Amazon that is amazingly loud and not expensive. I ordered two covers to keep the bugs and water out. Of course they are wired with a relay. Lots of room beneith my trike for the pump and relay.
For me an RZ seat & 14" ProAction shocks. Looking for Zook to do the Rake kit in June, then maybe it will be the best ?? :clapping:
I think one of the best accessories that contribute to your safety is frt and rear LED lighting.
visibility from the approach of your trike and view from the rear help alert cavers. Anything to quickly drawing attention helps. I am adding these from custom dynamics to my lowers.81A9DFAC-E8A2-47DF-B1A1-CF2273051DB2.jpeg
David,
FYI, without listing the type of trike you have, you wont get the advice you are looking for. Harley riders want and need accessories that Gold Wingers don't want or need. I think you ride a Goldwing, but the majority of those responding ride Harleys. Apples and oranges.
YEA I see that but still like to hear what they add to there ride. Like the sound of a air horn. Going to put on a fork brace too.
Trustme54
