Belly pan
Mar 13, 2012
40
5
Cypress, TX
Anyone have a belly pan on a MotorTrike Razor with floorboards? With the supports for the floorboards, I don't see how I could install a belly pan especially at the front.
My 08 with aqua shields made installing the prefab belly pan impossible to install, so using tin snips I modified it to fit.
Gerald
Mine is a 2002 GW MT Spyder with Floorboards. My oil is a front end change, I have seen videos of rear motor change is why I mention it. While having work done at the dealer, I had it installed. It has saved my bike as I live where there are rock slides around blind corners.
Hope you don't give up on getting it installed. Good Luck...Debbie
I have a belly pan on my Goldwing (Roadsmith) -------------NO Problems
Ronnie
5/31/22
nmbr1soonerfan
