Do not pin or set screw the axle.
Axle must be solidly tight. You will get some weird flex and gyrating if loose.
The best way I have found is turning a step on a spacer and press bushing into stay method.
In mine I was able to up-size the seal and that gave me the meat (metal thickness) to work with.
