baker plus 1 oil pna for t/g
May 8, 2011
755
25
Peru, IN
Leon
they have now re worked design & now have one specifically for the tri-glide.
as you know when I ordered my Baker p1 oil pan in 2009 . from baker , to
fit my '09 t/g they sent me a touring oil pan. well the drive belt rubs the
oil pan. I called them yesterday & they are sending me a new one to replace the old one.also said they had 2 other guys with the same problem.
BOTTOM LINE you can now get just under 5 qts of oil in the trike (no pukeing) oil either.
just info here. ROLL-ON & THROTTLE-UP!!
WILL POST A PIC OF BOTH OLD & NEW OIL PAN WHEN I GET IT.
finally got the correct oil pan installed. now have 1/4" belt clearance.trying to fing out how to post a pic.
ted, I had the dealer install it. they quoted me 2 days labor. I also had the drive belt replaced because I had a rock groove in the oem belt. maybe you could goggle it or try u tube.. lb
the 2 days was replaceing the drive belt. & while they were doeing that I had them replace the pulley. but didn't notice much difference while rideing, except now I can use 5 th gear more.
Desertgecko
