Assembly Instructions
I have my trike up on stands to do the timing belts. Figured while I'm in there I may as well go a little further and add the aftermarket shifter pivot.
How do the floorboards disconnect and lower to get at the shift side heat shields? Is a manual available?
BTW everything about the kit is so clean its amazing. Looks like it was installed just before I bought it.
Haven't found a reason for the vibration and noise when braking.
:D Dan :D
Thanks much for your kind Words and great to hear you are loving your Hannigan Trike ThumbUp
Give us a call at your convenience at 270-753-4256 and we will be glad to relay the Process to remove your Foot Fairings (Running Boards).
Same goes for any questions you have now or in the future.
Tom Wallen
