Armrest led tail lights install problems.
help! I BOUGHT THE LED TAIL LIGHTS (3240) AND THE HARNESS (3241) THEY REQUIRED. I HAVE SPEND TWO DAYS LOOKING FOR THE CONNECTIONS TO HOOK THEM UP TO AND CANT FIND ONE PLUG TO FIT THE CONNECTORS ON THE HARNESS. CAN ANYONE TELL ME WHAT I CAN DO TO MAKE THESE THINGS WORK? I AM AT MY WITS END. PLEASE!!! indypen@earthlink.net
Re: Armrest led tail lights instal problems.
Depending on the conversion, the connections are usually under the seat just below the tour trunk.
Depending on the kit and the installer they may have cut the connectors off and hard wired everything (sloppy) work. If you can't find the connector do as Hog Wild recommended and wire them to your trailer wiring.
The plugs definately wasn't easy to see but mine were there and almost out of reach, back up under the trunk/under the seat.
I went to my trailer plug in and spliced in there<img id="ums_img_tooltip" class="UMSRatingIcon">
I guess us old navy swabs can learn a few things from you ground pounders. I never would have thought of hooking them up that way. I also have a CSC Cobra 2010. Thanks again.
Marks2024
