Anyone have pictures of 2017 FLRT with tins and headlight removed
Mar 20, 2018
948
1,031
Saint Louis, MO
Jeff
Before I tear mine down to do it..... I thought I would ask. I need shots of the trees and all the "stuff" that bolts onto the Freewheeler's triple trees with the tins and headlight removed....
If you have any pics like that I would appreciate your sharing them....
Thanks Jack. I have used that link in the past and have the parts book too. I was looking for actual photos of trees with the things connected as the parts book has everything exploded and you cannot get a sense of things as they really are. Here the real story....
I am having a custom set of trees machined. I want a wide glide look to the front end rather than tins. I was going to buy HHI, but I want the actual trees to look a little more finished and less like somebody forgot to put the nacelle on. I "borrowed" a brand new set of upper and lower brackets and the bearing assemblies to reverse engineer the rake and necessary hard points for the steering dampener (an obvious one) and t-block assemblies. There are other things that I will not be carrying into the new design like the fork lock and attach points for the tins. The shop making my trees makes them for a lot of HD models, but he has never seen a Freewheeler or Tri-Glide "naked" (no tins/fairing). So I am trying not to have to tear mine down just to get some pictures unless I have to.
Here's what I am going for (conceptually... wider though like a wide glide)
I am looking for pictures like this on that I snapped off of a Youtube video but from several angles
Hope that helps clarify....and again, thanks for the guidance on the Ronnies HD parts catalogs.... they are a great resource
Trustme54
