I just went from an Ultra Limited to a new Triglide. I changed the stock bars out on the Ultra and was just wondering how many of you changed the stock bars on your Triglide and what bars did you go with? Thanks for any input.
Bruce, do you have a pic of the suicide shift? Can you tell me where you got it? Thanks.
Just wondering if you had a choice between 2" pull backs and the stock how many people would take the pull backs. I have stock but I am sure I would take the pull backs. It always seems sell a bike then let them make it ride able ho well smart business.
I recently completed a handlebar swap on my 2012 TG. I went with some new bars by Paul Yaffe called their "bagger bars" (not to be confused with their monkey bars).
They are dimpled and drilled for internal wiring but I didn't want to hassle with trying to run everything internally, especially dealing with the TBW on the right and the reverse wiring on the left. So I left everything external. I ended up extending all of the wiring six inches so I could keep the connectors in their OEM locations. I went 6" over on the clutch cable and installed new Magnum Chromite II brake lines. Of course, I went with all new chrome switch housings, master cylinder, clutch perch, and included Kuryakyn trigger levers.
I went with the 10-inch handlebar, which puts the grips even with the top edge of the fairing. The bike fits my six-foot tall frame much more comfortably.
While my fairing was apart and my bars removed, I also installed an oil temp indicator to replace the air temp indicator, and I added the ipod interface to the stereo. No problems as far as the wiring goes, but I had a heck of a time getting the outer fairing back on. I added a half-inch of foam to the inside of the fairing to improve the speaker sound and with the added harnesses there sure isn't a lot of room to get the outer fairing back on.
