MDF48
250+ Posts
Will Check
I will check on the tire carrier kit. The only one I saw at the dealer mounted on the right side behind where the frame starts it's v to the tongue. I have seen post from guys that said it throws up a lot of water on the side of the trike when mounted that way. I had rather have it up front also. I will check their web site and see if I just missed the front tire mount. I will also check with the local dealer about the stabilizer legs. Should be an easy job for a good aluminum welder. Thanks for the help and ideas.
