Aim Clutch Device Order
Status
Not open for further replies.
Jan 3, 2009
1,879
61
United States
Dave
Looks like several of us are going to order the AIM.
Original Post Here With AIM Link
The more we order the less they will be. So if you feel the clutch lever is difficult to pull this will reduce the pull resistance even for a stock clutch and help a stock clutch set up hold the power of even a built motor engage without slip at higher RPM's
If you are interested please post here. The list price is 245.00 but with a bulk order we can get a much better deal and save about 60 bucks on each one plus shipping. Post here if you have questions or are interested or just curious for more conversation.
I will chime-in here with REKSUL. I have had one of these devices for a while and am very well pleased with it. I am running an SE spring with the HD hydraulic clutch and having no problems at all. It will work with either the mechanical clutch lifting mechanisim or the hydraulic clutch. I have about the same pull as "recent" models. HD installs an updated version of the easy-pull clutch in the late models with a stock spring. Clutch pull has became a bit easier since then. This will only make things better....especially if you have a pre-06 model, or are running a stronger clutch spring due to the trike weight or engine mods. I ride a Lehman Renegade on a 2000 ULTRA with a Stage II upgrade intake runner porting and some other goodies. Clutch don't slip.
If you can get this at dealer cost...jump on it!
Status
snowking1979
