ADV
Sep 28, 2012
46
2
Buford,ga
Coach Rice recently Hanniganized our 06 GL 1800
What should I do with the ADV valve
My options are:
1.) Disable it with the hole in the nickel modification
2.) Service it and leave it alone.
3.) Remove .30 off the rod and add a small cone spring from a faucet repair kit.This will disable the ADV on "soft"normal braking,but will activate on "hard"braking.
I need to add I have Traxxion springs and a six degree rake
I would suggest that you contact Hannigan directly and get their recommendations on that subject.
My options are:
Called Hannigan.
They suggested that just the normal servicing is all that is needed.
What I got from the conversation is:basically the the upgrade to Traxxion springs and the fact it is a Trike,the functionof the ADV is less critical than a stock two wheel.
They mention that Honda had a recall/fix for the ADV??
KRC
