Can it be repaired?? Discovered a rather large crack in the trunk lid on the GW,and dont even wanna think about what a new trunk lid would set us back
Can it be repaired?? Discovered a rather large crack in the trunk lid on the GW,and dont even wanna think about what a new trunk lid would set us back![]()
You can have it plastic welded. Also if it's in a spot that is'nt too noticeable, I've drilled a micro size hole so the crack don't travel further.... start with the drill & a little pinstriping and see what happens from there, cause once you go the plastic weld route you''ll have to do some painting also....
You might try some black ABS cement and sheet of fiberglass.
<snip> .... After gluing the cracks, filling in the holes with the ABS cement (the black stuff has a solvent with ABS plastic dissolved in it) and touching up the paint I painted the inside of the trunk with a good layer of the cement. I then pressed a layer of fiberglass into the cement. If all the fiberglass didn't turn black I brushed a little more cement on It. This is just like laying on fiberglass with ABS cement instead of epoxy. .... </snip>
