A/C not working?????
Sep 23, 2013
171
10
Pensacola FL
Bobby
Any one had an issue with the A/C not blowing cold air? All I get is hot air.
#733 2010 Stallion.
Any ideas what or where I need to look?
TIA
Might check your freon charge. The charge fittings are underneath on the right side just forward of the rear wheel.<br />
Since the Stallion needs to be raised to do almost anything underneath, I purchased a set of steel ramps. I purchased them from Sears and paid a price, but they are heavy + the ramp can be removed once vehicle is on top. This is handy because sometimes the drive on ramp makes access a challenge.<br />
Another nice thing to have is a lightweight aluminum jack, one that will go down to about 3". The owner's manual will give you the jacking points.
There was a lot of hot air on my bike - mostly coming from the passenger area. She then got her own trike - whala - problem solved. <img src="images/smilies/grin.gif" border="0" alt="" title="big grin" class="inlineimg" /> <img src="images/smilies/laugh.gif" border="0" alt="" title="Laugh" class="inlineimg" />
check and see if the A/C compressor is kicking on or not is the first thing to check, if you don't know its the large belt pulley on the right side of the motor , with the ac turned on both the enter and outer ring will or should be turning ,if only the outer ring is spinning ,then the next step is to check the Freon very easy to , go to any car parts store and buy a can of Freon With The Hose and Gauge sold as a unit remove right side tire at the top of the wheel well you will see two caps like tire valve steam caps only larger he end of the hose will fit only one which is the low pressure side attach hose squeeze trigger and then let off to read the pressure gauge will let you know if you are low or not if lower just squeeze again slowly till qauge is in the green and your done ...
My A/C usually works best in Jan and Feb on my TG. Interestingly enough, my heater seems to work best in July and Aug. If only I had controls to switch that.:qpnmt:
Thanks Doc. I checked the compressor and it is working properly. I was at fault,I didn't turn the control knob in the right direction.
Thanks for all your suggestion on a fix.
Ride Safe
snowking1979
