2014 tri glide muffler
Replace the clamp. I had the same problem on a ultra. No matter how tight you tightened the clamp it always came lose until I replaced the clamp.
If the mufgler is not tight fitting you can use a coke can to wrap the header to get it tight. Just cut it in a strip and wrap it around the header and under the muffler.
2011Spyder*
