2013 trike rear brakes, and 4rotors
Mar 5, 2013
63
5
Hutchinson KS
Does any one no is there any rotors.
That will work on the 2013 trike.
Just check the coast of Harley rotors $250.
car rotors $50 and up. If any one has found a car or truck rotor that will inter change. I sure like the part # of them.
Thanks Big Red
Thanks Big Red
I believe they come as a kit now..2 rotors..in the kit.. Lyndall was making rotors but more money and I don't think they have them for newer trikes from what someone posted awhile back..
This has been researched in the past and has come up empty. So far no one has posted a replacement for the rotor other than HD.
been down that road
Be sure Harley is the only one who has or can get them for you believe it unless things have changed since March of this year. I had mine turned my dealer got mine turned free of charge. I purchased lining from them mistake! could have purchased two sets from any other supplier. :Shrug: ride safely fearless.
2013 brake rotors
I posted a response to this in another thread. I replaced mine with Drag Specialties part #19-11743 from Dennis Kirk for $118 ea. I do recommend lightly sanding the black coating off prior to installing. Didn't want it embedded in the new pads. HD dealership did not have OEM in stock and these were slightly less.
I used fine steel wool to remove the back anti-rust coating..👍
dhinzman1
