2012 air filter install video??
It's pretty straight forward. The whole thing is layered. Take the cover off, then take the filter off. Replaced filter in reverse. You will need a large allen to get the cover off and a torex to get the 3 filter bolts off. The filter bolts may have some blue locktite on them. You might want a very little dab of blue locktite when you re-install them. Just a little dab
Good luck.
I think Johnny is looking for some help on how the topshelter and dash come off on his late model wing.
Mick you are probably right. He didn't say what trike he was working on. And I did not look at the category.
When I did my first filter change I used a veido from YouTube. Now I just take it apart until I get to it. A suggestion, use some tape on each end of the wiring plugs and use letters or numbers so you can get them in proper placement
2012...
....is totally different. Mike was correct. No clue where to start. I bought Cruiseman's video. Only a couple wire connectors to unplug. Much, much easier than my '08. Being a trike Gozilla doesn't affect a filter install.
wzejda
