2011 triglide shocks
Nov 23, 2011
8
corinna,me
the only thing i don't care for is the ride on bad roads, is there any better shocks out there that will give me a better ride, thanks pete
what year is your trike, did the legend really make a big difference, i've heard nothing but good things about them but never talked to anyone that had them thanks pete
2010 Tri Glide and yes I noticed a less po go affect and smoother shock affect..
nothing beats independent suspension tho..DFT will convert the tri glide also i found out..
they have a kit now..
legend is expensive but you may save some money now around the holidays as i did last year.
Make sure you are NOT overinflating the rear tires. 20-22 psi is adequate for the 205-70-15 rear tires. Check suspension pressure in the airshocks too. Start at 15 psi and increase or decrease at your pleasuer.
FlintM
