2011 tri glide radio problem again.
It was worked on by Iron cross audio and it was working fine. After getting my clutch lever problem solved now this is going on. The darn thing was playing then just quit. Check all connections and all is good. It started to work again. Then it quit again. Don't know what is going on if I press on the front frame, it will come back on. Then goose off again. After a few times of this it is now beeping and saying not calibrated. Any ideas. Guess it is going back to the shop. Thanks. Old Hippie.
I just sent the radio out of my 2013 into Iron Cross late last week. Its on its way back to me already. About 1 week total turn around. Mine had quit completely. It wouldnt power up. Fuses all good. Hopefully this is a good fix.
Radio Quit.
Got mine back from Iron Cross. They did not warrantee it this time. It is working fine again. I did replace the handlebar bolt's when getting it back the first time. Hope it continues to perform for a long time. I do recommend Iron cross quick turn around on the fix. Have fun my brother's and safe ridding.
Gary Weeks
