2008 Stallion Trike Owners Manual
  • Thread starter
  • Moderator
  • #21
you have id ed the issue. the stock brake switched does more than just activate the brake lights. it has several contacts that activate the shift lock out and also disconnect the cruise control when the brake is applied. im betting your guy only fixed the brake light contact. suggest you get the wiring diagram for a 2007 ford ranger look at the brake switch section for help in connecting all the wires where they belong
It doesn't seem to matter how hard I push the brake. What position the brake is in. It won't shift into gear unless I press that button. One of the people who towed the trike (it's been towed about 4 times in 6 months) broke the little white thing in the hole under the gear shift. So that doesn't help shit, it's gotten stuck in the space of the button once already.
I thought I read in the manual that the keys were coded and that there was a safety system?
I was wondering the same thing because I only have 1 key and read in the manual that you need both original coded keys to make a a spare copy key. Manual said it's not possible with only 1 key unless you goto dealer to have transponder key programmed. So If keys are not coded then I should be able to have a lock smith cut a key and viola I have a spare 2nd key. :D
Missing Owner's Manual Pages Attached
This is the Owners manual for the stallion. Mostly 10 pages at a time all it would let me do.
The missing pages 61-70 and 71-80 are attached.
I had to compress them to a size small enough that the board would accept them as an upload.
They are still good quality even compressed.
  • Pages 61-70.pdf
  • Pages 71-80.pdf
Here are pages 71-80
  • Pages 71-80.pdf
Eddienorman
