Help? I never blown a fuse before on this. At the 2019 Sturgis rally I had a new ultimate seat installed, heated like my factory one and also went to blue tooth. Everything worked great. We washed/wiped down the bike like normal and covered it for the night. next morning turned key one notch and the gauges were not on. I checked fuses and the 20 amp was blown.
Thinking i might of got water some wear from washing, I tried another and it blew immediately like a direct short. It started right up and we rode to service place to have it looked at. Had to wait four hours for them to say they couldn't find anything wrong and the fuse they put in wouldn't blow. I still thought moisture from washing got in some where and after sitting in the sun for four hours waiting to be looked at it got dried out and will be fine.
It ran great, everything worked all day on all the different rides we took and that night we covered it without a wash/wipe down. Next morning turned key one notch and I heard the fuse blow so I tried another and it blew immediately. I drove it about 15 miles stopped tried another fuse and everything worked and it held all the way back to Montana. Parked in garage at home turned off and let it set for 10 minutes turned key one notch and it held. Next morning turn one notch and heard it blow. So it blows when its cold and if I ride for 15 miles or so and then put it in it good all day.
I do have an appointment on the 20th to have it looked at. Also the blue tooth and heated seat works great even with that fuse blown.Thanks
