2002 dyna wide glide trike / Frankenstein kit / oil reading
Sep 5, 2012
38
Urbandale
according manual - I have been told, the engine oil needs to be checked on kickstand.
Where on dipstick, when hot should the oil read with trike ??? Dipstick is either add or full.
thanx
I had that same question after I triked my Sporty. I checked the level hot, off the side of my driveway, angled to left side like on kickstand. Any way you can get it angled will work. Then I compared it to the reading when level. Now I know where it should be to check it when level.
About 1/4" higher. Your B.T. may be a bit different due to where the oil tank is located. You know to check it warm to hot, not cold.
OOPS, I meant lower when on kickstand.:xzqxz:
FlintM
