107" and 114" M8 Aftermarket Cam Shaft Comparisons
Mar 20, 2018
948
1,027
Saint Louis, MO
Jeff
The following cams were part of this test:
Andrews M460
Cycle-Rama 460
S&S Cycle 475C
Wood Performance-WM8-22X
Zipper's Red Shift 468
Wood Performance WM8-222
The first dyno chart below has all six of the camshafts overlaid to show their respective torque and horsepower relative to this particular set of components. All of the camshafts in the test offered significant performance increases over that of the stock camshaft.
Andrews M460 Camshaft
Valve Train Noise: Very Quiet
Cam Lope at Idle: Moderate
Description: This cam makes nice broad power. It comes on relatively early and pulls well to the right side of the curve. This cam placed in the middle of the test.
Cycle Rama CR-460 Camshaft
Description: The Cycle Rama 460 made very good low RPM power (the second best in this test), it also provides a very broad power curve with good upper RPM power.
S&S Cycle 475C Camshaft
Cam Lope at Idle: Very Aggressive
Description: The S&S 475C made the second best peak HP in our test, it accelerates hard. It is very responsive and has the most aggressive lope of all the cams we tested by a significant margin.
Wood WM8-22X Camshaft
Cam Lope at Idle: Aggressive
Description: The WM8-22X camshaft offers the best early torque in this test, and it faired well horsepower wise. This cam is easy to tune and has an aggressive lope.
Zipper's Red Shift 468 Camshaft
Cam Lope at Idle: Semi-Aggressive
Description: The Red Shift 468 placed in the middle of our test for both peak torque and horsepower. It has really broad power, nice and strong through the mid RPM's. It has a semi aggressive lope.
Wood WM8-222 Camshaft
Description: The WM8-222 made the best overall peak horsepower. It made slightly less early torque than the other cams. It has the smoothest curve.
The source data web page for the 107" is here:
https://university.fuelmotousa.com/...293-H-D-Milwaukee-Eight-107-Camshaft-Shootout
If you want a cam comparison for the 114" It is here:
https://university.fuelmotousa.com/...Milwaukee-Eight-114-Softail-Camshaft-Shootout
Good stuff......
There are a few newer cams out since that testing was done. Zippers has 2 new cams and I believe CycleRama has a couple also. It’s an ever changing field. One shop was testing the new CR cam showed impressive torque numbers from 2000/4000 on a 107/114. They called it a tractor build, so it should be pretty good for a trike.
Thanks.... I will see if I can dig up the dyno curves and summaries and post them too.
Zippers Red Shift Cam 472 - bolt-in grind for 114, 117 & larger M8
Work with factory valve train components, as well as modified heads with upgraded spring / valve combinations and porting.
A mid-range to top-end cam that maintains low-end torque. Cranking compression is only slightly higher than factory for easy starting
Quiet operation and long valve train life.
Found this to add to the study....
This is a great discussion of the M8 head's air flow and cam dynamics.... It is done by Zippers, so it is definitely a sales pitch for their cams, but it is also a good look into the engineering of the M8 heads and the needs of any cam design that aims to take full advantage of its design. Enjoy....:Dorag:
RODK
