Would like your opinion on which would be best to change to giv trike a lower gear.. Some say to go to a smaller drive belt pulley on transmission say 32 to 30 tooth and some saay to go to a smaller sprocket on the primary chain drive on engine shaft. Both would make it easier to pull a trailer and be 2 up on bike.. both take off from dead stop and a more usably 6th gear on the highway with the extra weight. Would it be easier on the motor using one method over the other? It would still accompolish the same thing in the end I think.. What do you all think???:Shrug:
