Hey guys, My neighbors Trike is blowing a 15A fuse. I have checked the circuit breaker under the rear seat. It wasn't tripped, but reset it any way. What happens is when you press the reverse button, you get the led to light up on the handle bar, and as soon as you press the bottom reverse button to back up it blows a 15 amp fuse. The fuse that blows controls the signal lights, horn and maybe brake lights. I need to double check about the brake lights.
I did take the front headlight fairing off and found a few wires that had rubbed through to copper around the radio, but it didn't solve the problem.
Also I have been reading about the parking brake and I don't think his is hook up. I put the bike in neutral and I can still roll it with the parking brake in the down position, so this could be an issue.
When I read the ohms on the load side of the fuse it reads around 2.5 ohms to ground, and then when I press the reverse button it goes to zero. I"m thinking the 2.5 ohms is filaments for the bulbs.
Everything will work on that circuit once you replace the 15A fuse as long as you don't put the bike into reverse.
Anyway any pointers on where to start or any wiring diagrams would be greatly appreciated. I'm not that familiar with Trikes. Thanks for the help. Russ
