Post Your Harley Trike Conversion Pics
Picked up this '99 Ultra Classic with a Lehman trike conversion in Mar '24. Absolutely love it (except for the Ford Pinto brakes) has Screamin Eagle cams and cam drive kit, reverse kit, Air button shift, Command Ign system. And a trailer to tow behind for all momma's goodies.2024-12-05 17.52.27.jpg2024-03-09 16.17.27.jpg2024-05-04 13.47.24.jpg2024-03-16 16.39.50.jpg
Here's my 2007 FLHTCU with the Lehman trike kit. Got it last June with only 14K miles on it and only 1,500 miles since the conversion was done. Rides absolutely great!
This is my first trike and my reason for my purchase was an injury to my left achilles tendon and not being able to support a full size touring two-wheeled motorcycle safely anymore.
Here is my 2006 softail standard , frankenstine 30" hotrod billet rear, 295/50-15 tires and 12x15 jeg wheels, sadlemen solo seat. Vance/hines big sweep pipes, Alen Ness super sucker and woods performance tw-44 cams
Jeff, doing a cursory google search, this is what came up first:
Based on the provided search results, Iowa law requires fenders on all wheels of every motor vehicle, including trikes.
Fender Requirement: The fenders must be designed at the widest point to cover the entire tread width that contacts the road surface.
Coverage: The coverage should extend from at least 15 degrees in front to at least 75 degrees to the rear of the vertical centerline at each wheel.
Purpose: This regulation aims to prevent debris from being thrown to the rear.
Zammy, thanks for the info I was afraid of that. I'm gonna play dumb for as long as I can.
Trike down
