Stripped floorboard bolt
Feb 8, 2011
58
14
Huntsville, AL
Steven
I was adding the DK floorboard extensions and the right front bolt head stripped. I thought no biggie, got out my handy dandy extractors…. And the bolt snapped off.
I thought ok I’ll drill the bolt and back it out with an extractor… the extractor snapped in the bolt.
Well after several hours with a dremel and carbide bit I removed the extractor. I drilled out the hole with a 5/8 bit and had to through bolt the mount with a 4” grade 8 bolt and nut until I can see about putting a helicoil in. IMG_2799.jpeg
Looks like the old bolt was maybe cross threaded. Looked like only blue loctite.
What a day!
Well after several hours with a dremel and carbide bit I removed the extractor. I drilled out the hole with a 5/8 bit and had to through bolt the mount with a 4” grade 8 bolt and nut until I can see about putting a helicoil in. View attachment 134278
What a day!
This is exactly why I bought different floorboard extensions. I had so much trouble with this exact bolt location I said never again. I don't know what HD is doing with this bolt but they really need to take a serious look at how they assemble the floorboards.
Glad you were able to work through this and get it corrected.
That does it. Now I've got the incentive to buy one of those induction heaters. The Mini Dokter looks good.
Been fighting that urge myself..It would rarely be used but could be really handy when needed. I just noticed that Amazon has one lower cost alternative to the Mini Dokter that is highly rated.
Trustme54
