Stripped floorboard bolt
Feb 8, 2011
66
30
Huntsville, AL
Steven
I was adding the DK floorboard extensions and the right front bolt head stripped. I thought no biggie, got out my handy dandy extractors…. And the bolt snapped off.
I thought ok I’ll drill the bolt and back it out with an extractor… the extractor snapped in the bolt.
Well after several hours with a dremel and carbide bit I removed the extractor. I drilled out the hole with a 5/8 bit and had to through bolt the mount with a 4” grade 8 bolt and nut until I can see about putting a helicoil in. IMG_2799.jpeg
Looks like the old bolt was maybe cross threaded. Looked like only blue loctite.
What a day!
That does it. Now I've got the incentive to buy one of those induction heaters. The Mini Dokter looks good.
When its broken off flush like that the heater doesnt do much. Other than drilling you could set a nut up against it and weld it in the center . Sometimes that frees the bolt enuff with the heat to remove it.
Well after several hours with a dremel and carbide bit I removed the extractor. I drilled out the hole with a 5/8 bit and had to through bolt the mount with a 4” grade 8 bolt and nut until I can see about putting a helicoil in. View attachment 134278
What a day!
This is exactly why I bought different floorboard extensions. I had so much trouble with this exact bolt location I said never again. I don't know what HD is doing with this bolt but they really need to take a serious look at how they assemble the floorboards.
Glad you were able to work through this and get it corrected.
Been fighting that urge myself..It would rarely be used but could be really handy when needed. I just noticed that Amazon has one lower cost alternative to the Mini Dokter that is highly rated.
I bought one a few weeks ago, it's for taking out car windows and urethaned on body panels $ 1100.00 had to get a rocker panel off a 2007 corvette, it worked great removed all urethane & panel bond adhesive right down to the paint, may not use it again for another year but it made this job easy.
I just checked mine yesterday on my freewheeler . I have had the right side off but not the left. All the fasteners came loose but I didnt remove any as I am waiting for parts to make my own spacer kit and move my boards out an inch.
Dave ...... Jackson,Michigan
KRC
