02 goldwing Hannigan kit the brake lights don't work.
Jun 29, 2025
4
1
Kentucky
Tracy
I have an 02 goldwing with Hannigan kit and the brake an turn lights stop working. Let it set over night and they work again for awhile an quit again where is the trike kit connection for the lights at.
I'm honestly not sure on Hannigans but I do know that the harness for the rear lighting on a CSC plugs into a CSC module under the seat. You may want to look under the seat and see if maybe some connection isn't fully seated. That would cause intermittent problems.
And just for clarification, is it all the brake lights and turn signals for both the trunk and the trike body? What about running lights? The reason I ask is that it could be a bad ground in one of the connectors that feeds the rear lighting. Take a look at this article and maybe check for this as well.
It’s all the lights in rear
Check that grey connector that is mentioned in the link I posted above. There are a couple grey connectors under the seat. It's supposed to be the large one you want to disconnect and inspect.
I seen a post on the grey connector on a goldwing forum of how to wire around ground around it I’m going to try that tomorrow.
Joe Henry
