ctdair
150+ Posts
16 TriGlide. Water pump went bad in 21. Extended warranty covered the conversion to new style. This morning Temperature light and check engine light on. Actually went out after I switched on Wards fans. P1019 code. Coolant level was checked pre-ride. Flushing has been on my to do list.
Manually cycled stock fans after arriving home. Couldn’t feel pump running and it was almost too hot to touch. Waited about 5 hours while doing other work. Manually cycle fans again no perceptible feeling of pump running. Next step is electric troubleshooting. Did remove the connection at the extension harness that’s part of upgrade. Little green corrosion.
Quick cleanup and still no perceived feeling of pump running. Tomorrow? Check for voltage at connections. I do have factory manual with electrical diagram. Is it really possible to feel the pump running? Has anyone tried and felt their pump running when fans manually cycled.
