Rear Shock Air Sensor Issue - 2012 Motor Trike Razor
Mar 9, 2025
2
4
Bacliff, TX
Donald
I have a 2012 Razor conversion and the air pressure reading fluctuates a lot when bike is being ridden apparently a sensor issue any suggestions on fixing?
I have not had a reading that I could read while riding, but I would think as you go over bumps and stuff on the road and the suspension reacts up and down the pressure would very. If it reads as its supposed to at rest then I think you do not have a problem. That's just my thinking I maybe entirely wrong.
your thinking is correct, as the suspension fluctuates while riding the gauge is gonna fluctuate to. if it stays steady sitting still, then its working correctly.
Ditto on the comments above.
My original digital readouts for the voltage and air bags pressure was very intermittent, it was off more than it was on. The small circuit board was faulty so I finally bit the bullet and bought the replacement digital readouts and installed it. At this point it works all the time but it definitely fluctuates a little while riding but stays at the fixed pressure when sitting still.
Ramjet73
